jmilkins
Digited User
OK. I might be sheltered, but I stumbled upon this image - has anyone any experience with a Leitz - Zuiko adapter? See http://www.smugmug.com/keyword/all/zuiko#157017107-L-LB
ChrisN said:Not sure what you need, but the whole range is listed here: http://www.cameraquest.com/adaptnew.htm
Edit: M lenses are designed to be placed closer to the film than slr lenses, which have to leave room for the mirror. Its easy to adapt slr lenses, which "simply" need a spacer, but to put an M lens on on slr will leave it too far away from the film/sensor to focus properly.
It's not impossible - I have mounted LTM lenses onto slr via adapters, but you can't focus further than about 500mm away! Makes a good macro lens!
jmilkins said:OK. I might be sheltered, but I stumbled upon this image - has anyone any experience with a Leitz - Zuiko adapter? See http://www.smugmug.com/keyword/all/zuiko#157017107-L-LB
ferider said:John,
I was gone for two weeks and just saw this (my photo) today.
Works pretty well with wide angle lenses. You see that I am using
it with the 28/2. But my dream lens to put on is the 21/2.
The Zuiko 28/2 is not much larger than the CV 28/1.9 which is not
much larger than the Summicron 28/2.
And, BTW, the Zuiko 85/2 is smaller than anything comparable in the
RF world ... But I wouldn't use it with the adapter.
The adapter only comes with 50mm frameline trigger.
Roland.
