lens fungus
FrankS
Registered User
1:25 AM
Canada, eh.
Can anyone post a picture of lens fungus? I don't think I've ever seen it and I was wondering what it looks like. Much appreciated.
I found this here:
http://herron.50megs.com/fungus.htm
From what I have seen it comes in at least 3 forms. one is a spiderweb type fungus, one is more in the form of random spots, one is an overall haze. I have had some that cleaned up nicely and a very few that had eaten into some lens coatings and would not clean up..
Thanks Rob and Kim. I have a lens on which I can see some lacey stuff held at a certain angle to the light. It's not hazy at all.
Hey Frank,
I thought I had a better picture, but this one shows the 'spiderweb' type on a Rollieflex MX-EVS. This has been my only experience with fungus... The camera was described as 'clean & clear' (ever heard that one before?)... Apart from the 2mm chip out of the front element it looked like someone had at it with steel wool! The fungus was just the iceing on the cake! Needless to say I returned it asap & got my money back.
Peter
Hi Frank,
If it looks like single filaments, it should clean. If it looks not so much like a spiders web but more like an enlargement of a snowflake, you may have problems as this is the stuff that secrets hydroflouric acid which etches the glass. Whichever it is do not dry to "dry" clean it but use a fluid. Alcohol, Rosonol or lens cleaner can work but some suggest something a bit more potent to ensure it is killed.
Kim
It does look like the enlargement of a snowflake. It can be killed with peroxide and ammonia, right? The onbly downside is that damage that already has been done does not come undone, right?
Hi Frank,
You won't know until you try it! I had a J8 that has been marked permanently but I have managed to clean others. Depending on the lens and the value, sometimes Flitz with a little bit of Naptha helps.
Kim
I 've successfully used Windex (amonnia versions) on lightly afflicted lenses.
-Paul
