Roger Hicks
I could not possibly carry everything I own, even in a small rented lorry. Not that my gear is top shelf, it's just the opposite, but there is a lot of it.
I do not disagree with you with regard to carrying superfluous kit.
I only disagree with the philosophical statement that less is more with regard to one's photographic output. Less is less. Being incapable of choosing an appropriate lens for a given situation because one has too many from which to choose reflects a personal problem. They gear did not conspire to make one a better or worse photographer or to confound and cloud the judgment of the photographer involved.
A semi-truck has dozens of gears. How on earth does a trucker choose which one to use? Thank goodness I have only five. Now, if I had only ONE gear in my vehicle, wouldn't that be dandy? Well, no, it would not.
Choice is good. If one does not have choices, one makes do with what one has. However, rejecting choices on the basis that it clouds the mind and renders one unable to select the appropriate choice? Please.
Dear Bill,
It's a question of WHEN you choose.
As you say, if you can't choose, it's your problem. But equally, it makes sense to choose a reasonable outfit for what you want to photograph.
My Land Rover has 16 forward and 4 reverse gears -- but I HAVE to carry all of them (assuming the overdrive is fittted). I don'thave to carry all three of my Leica-fit 90mm lenses, and indeed I'd be a bloody fool to do so.
