But the most important component - the sensor technology is identical.
I was under the impression it would most likely have the Q's sensor.
Stephen
Stephen
It is not going to have the sensor from the Q
Well that's what all the rumors say from every source right now so I'm gonna say yes, it will have a slightly altered version of the SL/Q sensor.
And therefore?Besides, the Q/SL sensor was already behind current tech. at the time Leica used it in those cameras.
... the Q/SL sensor was already behind current tech. at the time Leica used it in those cameras.
While I can't speak as definitively as Lightbender, there might be a chance that something would be different between Q & M10 sensor, if for no other reason than to compare what happened with the M-D 262 and the M240 sensors, supposedly being slightly different as well since the M-D had no need to support LV or Video.
Either way, I think it's optimistic / foolish for anyone to claim they know what the new camera will or wont have before the actual announcement, unless they happen to have some reliable & verified inside information.
The sensor is not going to be slightly different. The sensor is going to be completely different and that is all I can say and know. The camera is going to be quite refined in the way the Q and SL are. It is going to be more focused as to what a traditional M is.
excels in automated optical inspection systems, machine vision uses and prosumer video applications
The CMV50000 is a medium format 48Mpixels sensor with 7920 x 6002
The CMV50000 provides detailed views of a large surface area required in factory automation applications such as automated optical inspection (AOI) systems and systems for the inspection of displays of mobile phones, tablets, laptops and TVs. The combination of high frame rate and high re-solution allows further increase of the already high throughput rates at consumer product assembly plants.
Unit pricing is €3,450.
