Apologies for reviving an old thread, but I've just had exactly the same issue show up with my M2 viewfinder following a knock.
I was wondering what the latest is regarding technicians doing this repair in 2017?
Second the suggestion of getting it to Alan. He's real good and his prices are very reasonable. Also, he keeps you updated on progress and his work done through a special web address where you can just log on with the repair reference number. 12 month warranty too.
Wonder why I've never heard of this guy. Knowing there was an organised, not overloaded UK repairer would have changed my buying patterns...
Check with Youxin Ye, I believe he does re-glue separated prisms and might be more affordable than others.
A bit of an update for those in the Southern Hemisphere...
I contacted a number of people and received responses from Ernest at Camera Electronic in Perth and Peter at Accurate Instruments in Brisbane.
Peter basically said that they had never managed to repair the issue satisfactorily, and success they had previously had with microscopes (25 years ago) ended up costing significantly more than a camera would be worth.
Ernest claimed that he had managed the repair before and was happy to work on my M2, so it's currently winging it's way to Perth. If this doesn't end up working out I will probably send it to Youxin Ye.
I will update on the success (or otherwise) of the operation!
the key to whether it can be repaired lies in whether the mirror coating was intact during the split. in the process of cleaning away the old balsalm, some of the mirror coating might also come off, affecting the double image clarity or even the total repairability of it - so it might be tough for youxin to work on it as a second person.
Off topic, some Alan Starkie praise:
Bodies and lenses, all are repaints.
