Ororaro
I love the red dot!
Tom A said:One of my M4-P's dates back to 1982. i have no idea how many 1000's of rolls of film has gone through it over the last 25 years. It was my primary camera for about 5 years. After that it became my "test" bench for making Rapidwinders and was mercilessly beaten up in the shop (4000+ winders were cycled through it. 5 to 10 rolls per winder!) over 20 years! It was serviced quite regularly (every decade or so). The rangefinder went out of whack once when it was dropped and the intermediate gear train was replaced in the early 90's (using it to adjust drives on winders took its toll).
A year ago I had it stripped of what was left of the black chrome (not much!) and painted it black with a "textured" matte black finish. It still works fine and gets a fair amount of film through it, particularly matched to the compact 28f3.5 VC lens. So the 28 finder is a bit tough to see with glasses, but thats how it was from day 1 and I have gotten used to it.
My M2's are a bit smoother maybe and the M6's and MP are more convinient with its built in meters, but the M4P feels bullet proof!
TJV said:... M4-P, especially the ones made in Canada, are a real under valued item...
Thoughts? J
vrgard said:Ted - I haven't done a direct comparison between the CV II meter and the M6 but from what I can recall they are both considered pretty accurate. And I understand what you're saying about having to transfer a meter reading to the camera. However, what I've learned is to avoid taking meter readings for every shot and, instead, just take a new reading when the lighting conditions change significantly. Alternatively, you can meter for a couple of different conditions that you're shooting in and then just remember those two readings and simply reset your camera settings when you move between those two conditions (and, of course, all the other combinations that likewise work due to reciprocity). All told, I'm really enjoying this kind of operation rather than chasing the diodes in some feeble attempt to get some exact setting for each shot.
-Randy
BillBlackwell said:Perhaps you can tell me which ones were NOT made in Canada.
Most of the ~26,000 produced had brass topcovers; but the very last models (about 3,000 units) had zinc topcovers in preparation for the M6. Some of these are "said" to have been made in Germany, but I have never seen any M4-P point of origin indicating (engraved) anything other than "Made in Canada."
Congrats, you will like the M4-P 🙂 ... and it will arrive in one piece since it is build like a tank !TJV said:Well, I won the camera so lets hope it arrives in one piece!
J
FrankS said:.......M4-Ps are very good cameras, but gems? M2, M3, M4, and M5s are the jewels in Leica's crown, IMO.
maddoc said:I agree with that the M4-P is probably not meant for collecting or fondling but ... it "wows" people more than the M6, M3, MP I had or have 😀
I went the way M6 (sold) -> MP (now at service and will be kept) -> M3 (sold) M3 with M2 VF (sold) -> M4-P. I wanted a meter-less M body with 28mm frame-lines as 2. body and now the M4-P is my most used camera. Recently took it to a business trip (with the 50 Summicron Rigid and the 28mm Elmarit III) and it was just a great experience. Sometimes I use a hand held meter (Gossen Digisix) but mostly I estimate the exposure.
My M4-P was recently serviced by Youxin Ye and now it is like new again. The only thing I didn't like about the M4-P was the advance lever so I ordered a M3 type black one from DAG and exchanged it myself.
With Luigi strap and Summilux 35mm pre-ASPH
Hi !TJV said:Hey, am I correct in saying that this is the part you ordered from DAG?
The tools you describe to change it... Can you elaborate?
maddoc said:Hi !
yep, that's the part ! DAGM02 black M3 advance lever and the tool I used is: a flexi-clamp (I bought the Beryllium Copper version) from Micro-Tools. I bought two sizes, FLB-5-A and FLB-6-A but I have to re-check, which of them I actually used for the conversion.
It is a standard tool to fix / loosen screws with a plain shape. In the case of advance lever you have to unscrew the black ring-like screw around the shutter button on top of the advance lever. A flexi-clamp looks like this.TJV said:Is a flexi-clamp a standard or custom tool? I've never heard of such a thing...
