Bolo Kukus
Apple Genius appointment may be your best bet if you aren't pretty handy in the Apple OS.
If you are handy:
- Boot from an external drive, see what you can read on the internal drive. Hope it's just part of the internal drive that has the OS and you can see and read your files.
- Boot from an external drive, use a program to try to fix the internal drive.
- Boot from external drive, use a file recovery program. If the directory is corrupt, program may well be able to connect the data chains to give you a lot of files. You'll have the data (images) but problem is that all the directory information is gone (file name, date modified, etc.). You may still have the EXIF info which should be all you need for image files.
Good luck with all this.
Good advice from the (Kentucky?) Colonel. My own cautionary tale may serve as an example.
We are a Mac household - I run two Macbook Air laptops and my partner had a Pro. All three were bought from a reliable local shop in 2017 and 2019.
My two Airs have consistently worked well, even the one I dragged all over Southeast Asia on my wanderings.
My partner's Pro suddenly popped off last September. It was turned on and went Pop! (literally), and that was it. There were many vital work-related files and folders in it, so after home-tinkering a bit with it, without success, we took it back to the shop to be 'revived'.
Essentially, the shop expert followed Colonel Moran's third point and managed to retrieve all the files/folders except one - the most valuable of all - which had to be rewritten from memory and scribbled notes. All photos were safely salvaged.
The cost was over A$400, which is more than half what we paid for the laptop, a 2014 model. We did opt to not have the deceased Pro rebuilt, as we were advised it would likely expire in a year or less, from what the repair expert called "component stress", the strain of new parts installed on an older system.
The Pro was replaced with a (also used) Dell laptop of similar vintage, so it was back to Windows for us. The Dell has worked well since. Now everything gets backed up on two 2TB portable disks (Western Digital).
Once burned, twice shy, as the old saying goes...
