R
Rich Silfver
Guest
Some questions based on the first day of 'playing' with this camera:
1) I can only release the shutter when either the back is open - or there is film in the camera. Is this normal? I could have sworn that the M7II releases the shutter when the camera is closed and no film in it.
2) When loading the film and winding it onto the take-up spool I have to give it some 'slack' otherwise it just slips off the take-up spool and doesnt go onto it. Is that normal behaviour?
3) Going back to #2 - when there is film loaded the film advance is quite tough to move forward - not impossible or anything but there is just some apparent 'reistance' when advancing the lever. Normal behaviour?
4) Both on the feeding and on the take-up side there are small metal plats that are there to make sure there is tension applied to the spools as the film goes through it. Do you guys adjust these yourself or simply never touch them? Both of mine are sort of 'squeaky' and when advancing the film it is not a silent operation - there is some 'metal squeak' coming out of it.
Normal?
The camera is in absolutely wonderful condition cosmetically so I'm hoping these may be 'normal quirks'?
Oh, 5:
The 75mm lens takes 58mm filter I believe. What filter do you normally keep on your lens all the time to protect it? B+W UV, etc?
Normal?
Oh, 5:
