Microdol-x Developer.
4:28 PM
As part of researching on getting shadows with little details, i came across an interesting article on using tri-x at ei600 and developing it in Microdol-x for a very noir look.
( http://shutterbug.com/techniques/film_processing/0299sb_expand/ )
Another diagram I came across compared grain, sharpness and shadow details across developers several developers. Microdol-x is tops for fine grain, worst (or best depending POV) shadow details and worst for sharpness. (Not surprisingly, Xtol is tops or near tops for all three categories)
Another important point made by users of Microdol-x was the dilution with 1+3 was the most desirable but affected by long development time. Developing at stock would often result in loss of speed and general "mushiness".
I found freestylephoto.biz sound microdol-x under the name of legacypro mic-x. This came in power form and mixed with 3.8L (1 gallon) of water to make a stock solution of Microdol-x.
Armed with this information, I developed a roll of Tri-x at ei 250, 400 and 650. The first picture shows the ei600 with default scanner settings.
I then used a unique film Fomapan 400 to develop in Microdol-x. But I found the times for development only at stock and not at dilution levels.
Needless to say, fomapan 400 + undiluted microdol-x = major loss of resolution. Most of the pictures looked mushy, blurry with weird light effects, not dissimilar image quality from a lomo camera. The best picture I could muster up is fond in attached picture 2. I conclude that Fomapan 400 and Mic-x are best kept apart.
My next stage is to replicate the effect in Tri-x at ei 640 and perhaps Plus-X as well.
My development time:
8.0mins (was 8.5 mins previously) at 30C (!) tap water.
100 ml stock solution with 300ml water to make 400ml syrup.
Initial 30sec agitation followed by 2-3 inversions every minute. (was 4 inv every min).
raytoei
Microdol-X stock has a lot of sulfite in it. The 'solvent effect' is still debated, but whatever happens when you dilute it, the fine details get sharper.
Marty
7.5 mins at 30C (!) tap water.
Initial 30sec agitation followed by 3 inversions every minute
The picture seems a bit underdeveloped, the exposure was consistently done via a handheld meter.
Trix developed in Microdolx ei1600 developed for 10mins at 30c 100ml 1+3 dilution
Picture is resized and cropped.
M3 + 40Cron.
I got a very noir effect with little shadow details using Legacy Pro 100 (Fuji Acros 100) with Microdol-x.
My developing time is
ei200
1+3 Dilution
9mins at 30c (tap water temp)
cheers!
raytoei
Venchka: Yes. So much film/developers to try...so little time 🙂
I tried stand development + Push processing with microdol-x.
The film used was Plus-x a 100 iso film, I rated it at 400. For Microdol-x, the recommended dilution is 1+3, or 100ml syrup + 300 water. I used 25ml syrup with 375 water. At 30C, I soaked it for 90minutes, and 5 inversions every 30 minutes.
the pictures came out okay, but had a lot of debris (white spots, stains) and scratches, which i attribute to handling of film or insufficient washing resulting in residue.
Frankly at such dilution, Microdol-x loses its charm, it is neither smooth nor grainless.
I attach two photos which has been adjusted for contrast.
CL + Canon 1.8f 50mm lens.
If I were to do stand dev with Microdol-x again, I would probably cut down the development to 1 hour, and be more thorough with the washing.
