ferider
payasam said:Roland, I did a tape measure test. At 3.5, 4 and 4.5 feet, the Summicron's distance scale showed a distance slightly less than the measured distance. At 4.5 feet, for example, the scale showed just over 4 feet. My Industar 61 L/D, by contrast, was bang on at 1.1 m and 1.5 m.
If I were to do the tripod thing, Brian, I would have the lens axis at an oblique angle to the fence (or railings or whatever). I assume that is what you mean.
Here are two pictures taken with the lens at the same time, one at f/2 and the other at f/5.6. Both prints scanned in the same pass, nothing done other than cropping and -- to take care of the different colour casts the lab had managed -- desaturating.
Hi Mukul,
half a foot or less is not so bad for a 50/2 wide open. Only a film test will show if there is a real problem.
For final collimation check, I usually do boring stuff like this:
	Have to use a tripod though to avoid body back-lash.
But looking at your last f2 photo, I feel there might be another issue. Eyes are pretty much in focus, but the Summicron should produce a clearer picture. Can you check for haze with flashlight ?
AFAIK, Youxin does only CLA mechanics of a lens, not the optics.
Best,
Roland.
