HuubL
hunter-gatherer
What about methanol?
Strictly speaking, methanol isn't toxic. Unfortunately, the body breaks it down to formaldehyde (yes, that's the stuff you use in biology class to preserve things!) so it's rather bad news. It's also more flammable than ethanol (alcohol) and more volatile. It's a poor solvent for grease and oil, as are most alcohols.What about methanol?
See post above and yes it is used for denaturing ethanol. Industrial methylated spirit (IMS) is usually about 5% methanol, 94.5% or so ethanol and the rest water. Methanol is added to make it undrinkable because it's one of several things that cannot be removed by distillation (it forms what's called an azeotrope).It does not jump out at me if you are speaking hazards, do not drink it obviously, for cleaning, I think, with limited experience it is similar to ethanol, I think it is the normal denaturing alcohol added to ethanol to render it non- potable.
Common name is wood alcohol.
I would rank it a stronger solvent than isopropanol.
I heard of guys soaking bottoms of thread mount Leicas in benzene as a substitute for the time to tear the works down, not recommended because of the hazards
That may be a nuance lost in translation from German - pretty much any unpolar light hydrocarbon, like lighter fluid, gasoline/petrol and light mineral spirits is called "Benzin" in Germany (where petrol is now limited to less than 1% of benzene and its derivatives, and all solvents are benzene-free).
Sevo
Which property killed the people in Italy who drank it when used to fortify cheap wine, was it the derivative compounds? I recall blindness was another possible symptom? This is off the top of my head, but it is probably not a major item sitting about.
That was glycol, one of the main constituents of anti freeze. Apparently sweet and tasty, but deadly poisonous if not treated immediately!
helps ward off 'flu, John 😀I know that double alcohol is a bad one, does a job on the kidneys.
I was unaware that antifreeze since the mid fifties would have methanol in the mix.
Media reported methanol at the time, as I recall, but they get stuff wrong.
j
I believe the autoignition flashpoint for ether is 170 C. But that still is very low and ether is a real problem source of fires.
Earlier in life, I flew control line model airplanes competitively in the speed events. I blended some exotic fuels. Propylene oxide adds a extra punch to standard nitrometnane. Other engines used fuel containing ether and amyl nitrate. I always had some exotic stuff around the shop but always considered ether to be the most hazardous.
I didn't say they were safe. I said they were what works best. Here in France you have to give your address if you buy trike, but at least you can buy it. I use trike and ether only out of doors, with gloves on, normally only for swilling out shutters. But by God they work!
Tashi delek,
To clean grease or oil, I use Colorlok printing press wash, 95% naphtha, 5% ether.
I used to work for a printing-ink manufacturer in the 70s and 80s, we made blanket wash and yes, it does (did) contain some aggressive things! Several of the components are banned now. Then again, we used to supply lead-based inks to African countries, for foodstuff packaging - it was cheaper and it was allowed. In reality, the soluble-lead was negligible and people tend not to eat the packaging but H&S paranoia knows no limits nowadays.This sounds like what we used to use back when I worked in the print shop, the product we used was called "blanket wash" (after offset "blankets") and I've always wondered what was in it. It did smell kinda nasty. We would also use acetone during wash-down occasionally, and I've used that in the hospital lab, but it does destroy some plastics.
For my limited experience in camera repair, I've used mostly rubbing alcohol and Ronsonol, and for Ronsonol, a very little bit goes a long way!
