Are you sure ? This requires quite some strength in your fingers. You have to turn it to the right of the camera when you look at the camera from the back. Locking the mirror up before trying this will help (the mirror mech. won't be part of the deal then).
Once the back is closed you can't try to make the sprockets shaft turn nor can you see it...
Closing the back will only actuate the frames counter. You can remove the camera back (there is a spring pin at the hinge) for good until the problem has cleared, this might be of some help to understand what's wrong with this F2.
This is normal, the take-up spool is on a passive friction shaft.
Bottom line : I'm very skeptical about the posts in that thread telling about a design plague of the Nikon F2 shutter or the shutter jamming up because of some long time no use. This shutter is all ball bearings design and as one poster wrote it's probably the most reliable and robust 24x36 focal plane shutter made ever. Of course there is something wrong with this one but this might be for some other reasons than some related to how the shutter was built. One previous careless owner might have damaged something for instance. Even the best built cameras can be damaged by the "operator error" factor.
I have owned several F2 and still have two. None of mine have failed so far. The only problem I had was with dead CdS cells in a DP-11 finder.
