Swift1
Just finished this today.
http://www.coltonallen.com/getting-the-most-from-color-negative-film-with-your-epson-flatbed/
Would love to hear feedback!
brbo
Great guide.
Scanning color negative film requires a good eye (yes, I know, the folks with Pakons will now rush in to tell us this is not true), but I think you've deconstructed this process down to the steps that everybody should be able to follow and get good results.
Donation made (although I don't use Epson Scan).
ray*j*gun
I remember seeing this article before and lost track of it....thanks for posting!!!
I have an Epson V500 and this process works so well its scary that I used the scanner so long with out it.
mdarnton
This is a good tutorial for adjusting color in Photoshop, too!
xvvvz
It is a good example showing how EpsonScan is capable and why most people probably can get along with it just fine. Users should at least work with it for a while before deciding they really need to buy Vuescan or Silverfast.
Doug
Doug
Swift1
Great guide.
Thanks so much, Borut!
Swift1
Thanks!
I'm glad to hear it helped you.
Swift1
Doug
When I first started scanning, I really wanted Silverfast but couldn't justify the cost, so I just kept using Epson Scan and got used to it. Now I have Silverfast, and never use it.
PatrickT
New Rangefinder User
Thanks for this! I'll take a look when I get home.
Swift1
Let me know what you think.
PatrickT
Let me know what you think.![]()
Just tried it, and it seems to help! I'm going to play with it more, but so far, so good...thanks!
Trius
Waiting on Maitani
Thank you for the link - in addition to bookmarking I exported it to PDF as a handy reference.
I have a V750 and typically use VueScan, but this applies across the board.
Swift1
Let me know what you think of it.
charjohncarter
I read your first Ektar article and have been using it on all C-41. Another RFF member did something similar to you, but as I have a V500 yours should work better for me. I don't use paypal so if you PM your address to me through RFF I will send you a check. Thanks.
Swift1
Thank you, John!
