yossi
But coatings don't necessarily affect aspects such as focus shift and field curvature.
I received my lens and I have mixed feelings about it when used stopped down because of strong focus shift combined with "W" shaped field curvature. These are my impressions about it with my M240 after both casual photos at various distances as well as putting it on a tripod and doing some careful tests at a range of distances (because of the behavior I noticed in those initial casual photos).
If focused by RF at f/2 and not refocused:
f/2: is kind of glowy due to SA, but sharp enough, which I expected and fully accept, with good flatness of field across the frame.
f/2.8: increases contrast a lot and there seems to be a touch of focus shift, but not much. Center frame sharpness is slightly underwhelming and signs of a mid zone drop in sharpness.
f/4: focus in the center 1/4 to 1/3 of the frame shifts considerably behind the subject while the rest of the frame is pretty sharp with signs of a mid zone dip.
f/5.6: focus in the center shifts even more behind the subject and affects about the center 1/3 of the frame, while the rest of the image remains sharp.
f/8: depth of field begins to recover central sharpness and the outer 2/3 of the frame is good. But central sharpness is still not acceptable, nor as good as the outer 2/3 of the frame.
If I use live view and refocus as the lens is stopped down, the center 1/4 of the frame is sharp and the rest of the image shows considerable field curvature towards the camera. Even depth of field at f/8 is insufficient to recover the mid zone of the image, though the very edges are sharp.
For example a scene nearly at infinity, based on RF focus, f/2 was accurate (as sharp as can be expected). Refocusing with live view at f/4, optimal central focus was with the focus ring at around 10m to get 'infinity' in focus in the center of the image (the rest of the image at that distance is very soft). At f/5.6 optimal near infinity central sharpness had the focusing ring between 5-10m (again, the rest of the image is soft at that distance). At this point, looking through the optical viewfinder, the RF patch was significantly out of coincidence.
I can confidently RF focus my copy at f/2, and with slight front focus, f/2.8. As the lens is stopped down, the "W" shaped field curvature becomes very strong, shifting optimum center sharpness away from the camera and making RF focus placement at f/4 and f/5.6 very difficult without resorting to live view. However, if I RF focus at f/4 or f/5.6 and place the subject in the rule of thirds zone, it will be correctly focused. It would seem the lens's RF calibration is set to cut through the middle of the "W" to keep good average sharpness across the frame but sacrificing the center at f/4-8.
Based on the MTF and field curvature documentation supplied with the lens, it appears "W" shaped field curvature is a characteristic of the lens. What I'm unable to determine from using just my copy is whether its performance is consistent with others, or at the extreme end. In other words, can you RF focus your copy and get a sharply (or acceptably) focused photo of your subject dead center in the frame at f/4 and f/5.6?
Ideally, I would like to use the lens for both wide open character/rendering as well as stopped down use (with good across-frame performance). Maybe it's too much to expect from this era of 35mm design?
Mine is a BP version and I believe it also has some weird field curvature at f4 and f5.6. It is not quite the same as your case though.
I did not use tripod to test focus but some handheld shots show that at f4 and f5.6, the sharpness is not even across the whole frame. At f2, focus is spot on.
Below is a shot at f5.6. Focus was on the first tree on the left (sharp, even a small lizard is clearly visible) but just look at the other 3 trees. The second last one on the right is most unsharp and strangely, the very last one becomes sharper ?!! (click on the image to see a bigger one)
I really don't know what is the cause of this. Maybe someone could enlighten me 🙂
