Xmas
Stu
Yes the 35mm adapter is the same as the 135mm adapter, you get both on an M4,...
Noel
Noel
Stu W said:Randy, mine was a screw mount lens with a standard screw to m adapter on it. The only reason I mentioned it is that I actually overlooked the adapter on initial inspection. Also, doesn't the 35mm lens bring up the 135 frame on an m3? Stu
FrankS said:Randy, with your Summaron mounted on an M2, M4, or M6, the 35mm framelines come up, right? Does the lens' focusing scale agree with the camera's RF when focussed at a close object, of say, 6ft?
Paul Connet said:Ghester Sartorius, in his book on Leica lenses notes that the Summaron was initially adapted to the bayonet mount without eyes and required the use of a shoe mounted viewfinder. It was later modified by adding the eyes for the M3. He notes 20064 were made without eyes and 19,141 were made with eyes for the M3. He makes no statement regarding how the mounts were cut to bring up frame lines.
I would suspect that already in 1954 they knew that they would make the M2 with 35mm frame lines and that is what the initial batch of Summarons was aimed at. They probably got a bunch of complaints about having to use shoe-mounted finders so created the Summaron with eyes.
My conjecture only 🙂
Paul C.
