Ricoh
Thanks for this, lukx.Someone with more more knowledge might correct me on this, but I think it's because of the way the mirror and prism directs the light. I am not certain on the details, but basically you are not looking through the lens at "full width", but get more light from the center than you get from the edge of the glass, which is equivalent to stopping down the lens. So if the lens has a little focus shift wide open as is common, the point of focus will be slightly off.
I found that when you use a fast lens and press the depth-of-field preview button while looking through the viewfinder, you can turn the aperture ring and will see that viewfinder image only darkens noticeably after f2.8. Before that it will be the same brightness, no matter whether you set f1.2 or f2.8.
Look here, too
But you can lern to predict this behaviour and ever so slightly adjust focus. It will mostly matter when shooting people wide open and up close.
I have about 8 shots remaining in my FM2n so I’ll shoot some trial shots using the f1.2 with camera on a tripod.
Thinking about focus shift, I get some of this on my Leica RF, but the reason is different - something to do with lens design I guess.
