The Nikon S2 isn't a Kiev, there isn't the least risk of getting the shutter to malfunction if you change speeds before you wind (given that you align the speed with the arrow of the central moving disk, which isn't at 9 o'clock when the shutter isn't cocked).
Slow speeds all acting like T at 1/15 and below is the sign of the slow speeds escapement being gummed up and in need of some service (a routine clean with lighter fluid will do it and, fortunately, the escapement is very easy to find without having to take the whole thing apart).
As of this morning the camera is still working nicely at all speeds, checking them with a tester tells me they are all within 1/2 stop (the limit of my cheap tester).
Good to know I can address the issue, if it happens again.
Joe's warming technique seemed to have done the trick, and I'm assuming there was a bit of cold lubricant causing the issue. I haven't been able to replicate the issue after 30+ advances and releases of speeds 1/15 and below.
Should be safe to say its good to go, I won't be returning the camera now.
Tom, that's one hell of a system you have ready for March!
I'm planning to shoot mostly Tri-X 400 and T-Max 100 this month, with a roll or two of P3200 thrown in at night.
I was wondering, also, if the later F reloadable cassettes work in these cameras?
How can you best tell the difference aside from some being marked "F"?
Will any of the Contax/Ikon cassettes work also? Im planning to grab a few 100' rolls of Ultrafine 100 and 400 and would prefer a handful of brass cassettes over a box of plastic reloadables (I already have)
Still on the hunt for a lens, now that my order has been canceled.
I have a reserve on a black 50/1.4 , I will be picking it up March 9th at our local swap and show in Dearborn Heights.
I've also been watching a 35/2.5 and 85/2, but may wait until I first get the 50 to actually buy. Hoping to get to shooting asap.
