I have an idea for something crazy in your life Cal...
Your 250 stovebolt, if original to your truck, is one of the greatest engines ever made. Chevy kept that same basic engine in production some 70 plus years. The V8 hasn't even caught up to those years yet I think. What I'm saying is you have something mucho cool.
So here is the idea...how could it be even more mucho cooler? Well put a 2 barrel Weber carb on it. Put some 307 flat top pistons in it they'll drop right in. A high lift solid lifter racing camshaft. A steel crankshaft secured with studs. Some headers and dual exhaust cherry bombs. Update the distributor to hei maybe get a MSD ignition. Finally a 3 speed Muncie and 10 inch rear end with 383 gears. Might need some good disc brakes and maybe some drag radials.
Now that's what I'd call happy fun crazy! 🙂
C,
I have been looking into Stovebolt.com. Seems the head is a bottleneck as far as breathing goes. This guy Tom has these things that are called “Lump-Ports” that create a curved better flow for good breathing. He built a 320 HP motor and has a video of this engine getting run up on a Dyno. The engine is a screamer, has a crazy mean tone, and is very musical.
Anyways a lot less expensive than a E-10… Cooler in a different way… and since this 1966 C10 is so OEM doing what everyone else does (swapping in a V-8) is not so appealing.
I love the sound of “Flow Master” mufflers which pretty much sound like a straight pipe. Pretty much my Jeep Scrambler in second gear (NV4500, 200 pound cast iron tranny, 3-speed, with a 6.31 under drive, and an over drive) sounded like a NASCAR on a straightaway whenever I stomped the gas. I had headers, dual 2 1/2 pipes to the rear, and Flow Masters.
Mucho nasty. My friend Steve taught me that you can ID a fast car when the time between shifts is very brief. Fast cars that have a lot of power redline a gear in just a moment if geared right.
The tranny I like is a SM 465 and was available in later C10’s and other Chevy trucks. Of course cast iron. The old Jeepster in me likes having a granny just in case, but my experience is if you have the right gearing in a drag race all you need is two gears (a high and a low), and that 3 speeds is enough. This tranny is like the 250 Stovebolt in that it was used for a long-long time.
Anyways 4 wheel disc is only complicated if I want to try and retain the OEM steel rims so I can use the “Dog-Dish” hub caps to keep this truck a sleeper and OEM. Also there is manual steering which I wast to preserve that limits at least front tire width. My rear end gearing is 3.73 and the rear likely needs to be upgraded to a posi.
The body and paint is well preserved and it will turn heads parked or driving because it is clean and factory OEM.
First I have to pull the head and have it sent out for a valve job and new valve seats. Unleaded gas destroyed the old OEM seats.
I have to replace the rear main seal on the engine, an ugly job, and then also put in a new clutch because the OEM one is likely oil soaked.
I need to replace the dry rotted tires.
Cosmetically all the truck needs exterior body wise is a new wooden bed. Cost for a red oak kit with hidden bolts for a clean look is about $1.5K. I’d use a red gel stain and then put poly over it. A green truck with a deep red bed would be a bit loud and have “Calzone” factor.
This morning I woke up and I figured out what is missing in my life, the part of me that some say is crazy, and now I know that I need “Passion” to feel alive, where I’m not like everyone else, otherwise I feel deadened.
Thanks for your kind help, but I kinda figured it out after 10 hours sleep.
My core is sore from pushing a jogging stroller yesterday. Spent some time in Blue Mountain Preserve. The “Critter” loves being outside.
Cal the “Gas-Guzzler”
