Calzone
Gear Whore #1
- Local time
- 12:38 AM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
I did this once before: I built a crazy Jeep Scrambler with a Corvette engine and Ford 9 inch rear axel with disc brakes.
So now is a bit more complicated bigger project. Kinda exciting.
No Limit did all the engineering and assembled me a kit for suspension, steering and brakes. What I love about the C-10 is that the aftermarket is so developed to the level of Jeep CJ’s.
It does seem though that the engineering is mucho much more advanced, even more than a Jeep. I kinda learned enough that just changing to lowered springs can have a bad effect on handling and ride quality.
I still favor an upgrade to a 292 I-6 over the stock 250 I-6. After breakin I can add a cam and a worked head. Intake and exhaust can be done on the long block. HEI electronic ignition is about high tech as I want to go.
With the Jeep I really had to dig in and research all the possibilities. Use of some OCD behavior in a good way.
Since I intend on keeping the 3-on a tree tranny, I save money, but also I honor the truck as a cruiser. 127 inch wheelbase to approach my Checker Limo ride. I have no shortbed envy. Lots of long beds and frames have been cut down… Short beds are more popular for hot Rodding. Going countertrend is more my personal style, it is bolder.
Even though this suspension is involved, no welding required. The front suspension is designed using 2d generation Camaro stock spindles and brakes and the front rocker panel with a 27 inch tire sits about 6 inches off the ground. Mighty low without drop spindles.
Thought has passed my mind of getting into welding. Not a bad side hustle and I already have a hundred amp service in the garage. In art school I was strongly encouraged to embrace sculpture because of my aptitude. Hmmm.
Seems like I am right in the way to the Hot Rod Hotel. Pretty much to go there you have to pass my Baby Victorian. Bear Mountain has the car Meet-Ups on Wednesdays. I have a dead end… You know me, “I just mind my own business” and then all these things just happen to me.
BTW even though hidden in my garage my truck is lusted by anyone who sees it. The body and patina are that great. I love the contrast of a Rat-Rod body with faded patina and a modded/updated chassis.
The slope got filled in a bit today in the back-backyard. This fall I imagine the short chain link fence I relocated on the ledge I built out will get hidden by the leaves I round up. It took a lot of clean fill to get to this point.
Cal
Cal
