jlw said:
If you don't believe that mechanical parts could be designed to operate without lubricants, remember that old mechanical clock mechanisms also were designed to run "dry." Oiling an old clock will ruin it, and for basically the same reason it's bad for diaphragm blades: the oil attracts dirt, which accelerates wear.
Not exactly true. Old mechanical clock movements REQUIRE proper oil and grease to run. The emphasis is on proper oil: pure and non-migrating, and proper lubrication methods: tiny amount at pivots (the "pins" that hold the gears into the clock plates) or on sliding surfaces. Without lubrication, clocks don't run. Even clocks using jeweled mechanisms like watches need oil at the jewels.
There are companies that have worked for generations developing fine watch/clock oils/greases. These oils and greases are subject of considerable scientific improvement even today. Once it was common to use biological-based oil - sperm (whale) oil, then petroleum-based oil (Nyoil, for example) and now synthetic oils tend to dominate this specialty lubricant market. Greases, too, have gone through similar evolution.
I believe what you intend to emphasize is that there are parts that are meant to be lubricated, and parts that are not meant to be lubricated. Those that are lubricated are not intended to run forever without periodic PROPER cleaning and PROPER re-lubrication. And improper lubrication will lead to premature failure of the device - whether it is a clock, watch, or camera.
The problem in clock lubrication is MIGRATION of the oil... just like in camera shutters. If too much oil is placed, even in the right place on a clock, it will migrate away and not provide lubrication at the pivot point where it belongs -- the oil will simply gunk up the clock plate and make it dirty. In a camera, as you say correctly, too much oil in the wrong place will migrate onto parts it doesn't belong on and gunk them up -- leading to a different type of failure/damage.
It is true that oil attracts dirt and dirt causes wear. In old clock repair it is common practice to re-pivot -- replace the pivot by reaming out the old one and re-fitting a proper sized bushing in replacement. The pivot wears out from one of two reasons: lack of lubrication, or the abrasive grime that builds up in the oil. This is one of htose 'darned if you do; darned if you don't' situations - the oil keeps it running smoothly but leads to eventual wear; but the wear is going to happen with or without oil.
There are some leaf shutters in cameras that are alleged to be designed to run without oil; there are others that won't run at all unless they are properly oiled. Those skilled in leaf shutter repair know the difference. Those not skilled will goop up the mechanism with lots of 3-in-1 or WD-40 and cause the shutter to totally stop sooner than later.
In conclusion (since you inspired me to get on my soap box... one which I am most adamant about because of the large amount of incorrect information floating around the internet by people who are both trying to properly learn the trade or, alternatively, are trying to effect a quick-fix without too much concern for longevity of repair), let me re-iterate the following:
Mechanical clockwork devices, like clocks, watches, and shutters are not intended to run forever without periodic PROPER cleaning and PROPER re-lubrication.
