keytarjunkie
no longer addicted
Any advice??
My 67 lenses don't seem to quite focus to infinity on my 67II (they do on an ancient 6x7)- is there a relatively easy check/callibration/adjustment (focus screen or mount shim?) or should this go straight to repair or?
Pretty sure it's body not lens as three lenses show same.
thanks - danny
make sure the film plate is set to 120 if you're using 120, and 220 if you're using 220...the only other thing that could be off is the lens mount could be a bit too far away from the rest of the camera so make sure it is completely tight. that's about it...
