You have the Voigtlander 21mm f3.5 right? That lens on the GFX covers 65:24 and is almost the exact same FOV as the Xpan with the 45mm. In 1x1 it is same FOV as the SWC. Very fun lens on the GFX.Fun with my wannabe digital XPAN camera
(in other words, my GFX50R with aspect ratio set at 65:24)
I don't have the GFX any more but I had a couple of different adapters. The worst was the Novoflex, it was way too thin and had to be shimmed quite a bit to get it closer to proper. The inexpensive TTArtisan was closer to correct. Obviously, not all lenses will cover the entire sensor but if you are using some of the other ARs they can work well.
The Voigtlander is a tiny little lens on the GFX
but worked well in 1:1 and 65:24
Vault beach, Cornwall. 14 second exposure. Fuji GFX100S, GF20-35mm lens. 10 stop plus 6 stop ND grad filter.
Very nice, Mark, well done. What tripod and tripod head are you using?
All the best,
Mike
