Please help me in these questions
cralx2000
9:37 AM
1. Can I leave the chemicals in the trays overnight?
2. How is the process of fixation in two stages?
3. What is the purpose of using hot developing with a brush on specific areas?
4. How do I choose the correct contrast? What should I look for to make this decision?
5. Can I use left over paper cut out from another project that hasn’t been used?
6. Do I always need the test strip?
7. What is Dodge and Burn?
8. Do I need to clean the negatives every time I do an enlarge?
9. What do I do to prevent the fiber paper from rolling after I reveal it?
10. What is the expiration of the chemicals?
11. How do I test for light leak of the lab by light? Is it right that I have to test it with a piece of paper on the table?
12. Can I use a red safety light with contrast paper?
13. How can I tell if the negative density is good?
14. Is it better to stick with the same develop until I learned to do it right or is it ok to change it with every job?
15. Can I use the same fixer for film and paper?
16. Do I need a Hypo after using a fixer?
17. How long do I wash the papers? Can I use running water or top water in a tray?
18. What is the Ilfochrome process ( positive papers for enlargement in slides ) Is it still used taday? Is it worth it or is it better to scan and print in an inkjet? How do you do the contrast masks?
Thanks All
I was going to attempt this, but then I realized it's mostly printing questions and not actual development questions.
It would be nice of someone to actually answer these, though, so that if someone comes looking for the information at another time all we have to do is point to this thread. 🙂
You are, I think, presuming on others' kindness a bit to ask 18 questions which could easily take an hour or more to answer, so I'd second the suggestion to buy a book. Preferably one of mine, of course... (try Darkroom Basics -- it's on www.rogerandfrances.com)
But maybe if I answer Question 1, then someone else can answer Question 2, etc.
Yes, you can leave chemicals in the trays overnight if you put cling-film over them -- in contact with the chemicals, no significant air-space.
Roger
Ah, it's quicker just to answer these than to shame him into reading up for himself. Bear in mind, though, that just to keep it interesting, I have deliberately inserted AT LEAST one wrong answer!
Developer loses activity when it absorbs oxygen, so it probably will go bad. Stop bath and fix should be OK, except that they'll stink up your house. To extend the life of solutions in trays, float a sheet of plastic film wrap on top.
It's a way of making sure fixation is more thorough. You divide the fixer into two trays; the print spends half the total fixing time in each tray. The idea is that the first bath (which will wear out first) does most of the work, then the second bath finishes the job.
Lets you darken these areas selectively.
Lightest tones should show detail; darkest tones should look black; midtones should look normal. If white or black shows no detail, your contrast is too high; if whites are OK but blacks look grayish, your contrast is too low.
Sure.
No, but until you've become a very experienced printer, a test strip will save you time and materials.
Dodge is a brand of car. Burn is what Iraqi insurgents do.
You should at least blow off the dust. Otherwise, if it looks clean, leave it alone. You might scratch it.
It'll always curl. Flatten it in a dry-mount press.
It varies, depending on the chemical and how you store it. Developer expires soonest, fixer next, stop bath lasts the longest.
Yes, that's the only sure way.
Yes, although it's harder to judge tones under red light than under an amber light.
Put the negative over a sheet of regular-size print (e.g. a book) in good room light. You should be able to just barely read the type through the densest areas.
You'll learn more if you stick with one type until you learn it thoroughly. Same for films.
Yes, but film exhausts it faster, so it won't last as long.
"Hypo" is just an old-fashioned word for fixer.
The instruction sheet that comes with the paper will tell you how long it needs to be washed. Resin-coated papers take the least time, double-weight fiber-based papers take the most. If you wash in a tray, it's best to use a 'tray siphon', because fixer is heavy and sinks to the bottom of the tray; the siphon gets it out.
Some people use it, but scanning is easier and generally gives better results for most people. Making contrast masks is a very advanced topic, and is one reason more people don't do Ilfochrome. I would suggest avoiding it at least until you are a very experienced b&w printer.
Gotta take isssue with jlw's answer to No 15. All the reading I have done, and the one time I was tricked into using fixer for film that had been used for paper, I would say never use fixer for one that has been used for the other. From reading years ago, the advice was always that in a emergency, you could use fixer on paper that had been used on film, but never vice-versa. That was in fact what happened to me in an Army craft shop one time. The Korean instructor must have been having a bad day. I immediately realized the fixer was used when some of it got on my hands. He never lived that down the whole time I was there. I made him mix some more fixer and then washed and used that to clear the negatives. Wasn't the best for the negatives, but was the best I could do. I don't know if the paper does something to the fixer, leaving in chemicals that wouldn't be there from film, or if it just exhausts it faster.
Roger Hicks, or any chemists, can you answer that?
jlw's answer to your question #16 is correct, and since hypo isn't used often these days, that often confuses people. However, from the wording of your question, I wonder if you meant did you need to use hypo-eliminator after using fixer (hypo). If so, the answer would be it is convenient, as it reduces the amount of washing time needed, and no matter, helps insure all the hypo gets out, thereby giving the print a longer life. Btw, it is only used for paper, as fixer washes out of film much easier.
If you have further questions, doen't hesitate to ask, but please only ask one or two at a time. How many do you need answered at a time anyway, or can you absorb at one time? Do try to get books and magazines on photography. They will answer most of your questions. Roger Hicks does have some good books that are worth your time to read and keep on your shelf. And how cool to be able to brag that if you didn't understand something, you were able to ask the author? (just try not to bug him too much if re-reading something will give you an understanding, or if a general question on the board will get you more insight and experiences in your answer).
JLW,
You sir, are a saint. I looked at this thread several times last night and just couldn't bring myself to answer all of the questions.
It kinda reminded me of "instant gratification" required by the new generation. "I need this done now Dad! What button do I push?"
Wayne
About using the same fixer:
-- With rapid fixers, you need different dilutions for film and paper, so it's best not to mix.
-- With regular (sodium thiosulfate) fixers, you can use the same dilution. But film requires more fixer capacity than paper. So if you have some fixer that's already been partially exhausted fixing paper and then use it for film, it may not have enough capacity to fix it fully.
With film, if ever you pull it out and see it has a milky appearance from unfixed emulsion, you can save the situation by refixing it quickly in fresh fixer.
No, once you master the craft or when you are doing small prints.
Dodge means exposing areas of the paper less (dodging light) to make them lighter
Burn means the opposite
Yes, use the same concentrate but have 2 separate working solutions.
I think you are refering to Hypo-Clearing or wash aid
HCA is great for fiber papers, since it helps cutting wash time. No use for RC papers.
Hypo Clearing is just a sulfite solution.
RC papers need short wash times 2-5 min
FB papers need longer times (1 hour or so) unless you use HCA and then you can shorten this times.
You described it perfectly. I haven;t used it in years but it was the only way to do it before digital.
19. How do you do the contrast masks?
Look in Lynn Radeka's website
Are you already developing? The questions are mostly printing, but a few of them make me wonder if you've developed anything yet. Some of them are rather esoteric for someone getting ready to dunk his first roll of film.
Maybe he's just trying to get an explanation of some terms he has seen, so he can decide whether or not printing is something he is prepared to tackle. In that case, asking all the questions up front is perfectly legitimate and deserves an answer.
Printing is not as complicated as some websites and books make it sound. There's a lot of craft that goes into getting good results easily, and this can be learned only by practice. But as long as you're willing to experiment and make mistakes, you can get good results even as a beginner.
I've told this story before, but once when I was attending a photo workshop, the instructor praised the quality of my prints and asked if I had any secrets. I said I have a special piece of equipment in my darkroom... she asked what it was, and I said, "A really big wastebasket." Basically, that's the secret to getting good prints -- the willingness to throw out what you just did and try again.
I have this philosophy for when I start printing: paper isn't that expensive so don't sweat a bad print. Learning things takes time and patience on the part of everyone involved in the process.
Also, I think that this thread may be a good one to sticky for those who are just starting out printing. With all the questions answered, we can just point them to the thread if they have a question that's already answered and they can post new ones here that aren't answered. Keeping it all in one thread may help everyone...not having to look for a bagillion different threads on the subject is good. 😉
