Can't find much info on AD43057XP chip. So not sure if it's 8, 12 or 14bit like the later AD converters. The later 14bit AD9243AS chip is well documented.
And indeed those control boards look different.
I'd be interested to know if they're compatible (i.e. can you use <200 board in >200 SM11K)? And how they compare scanning quality wise - i.e. does the older board have its own issues (i.e. jaggies or the stripes in the shadows or noisy highlights issue)?
I have the newer board with 14 bit AD and had to send it to ABC Scan for modification to remove the stripes in the shadow issue that seems to be common quirk on all 11Ks according to ABC scan, would be interesting to know if it affects the older <200 boards as well?
