presentation of images from 4x5
nikonosguy
1:51 PM
not sure how to do presentation --- do i do 4x5 contact prints --- seems small --- how large should i go?
and what about 4x5 e6 --- how would i display chromes in a gallery?
kind of looking for a little shock and awe with the presentation
4x5 contact prints can work well in oversized mattes, to draw the viewer in. Transparencies you could present in little shadow boxes, or backlit constructed frames that play off the subject matter ... but either way, those build off intimate discovery - not shock and awe.
Shock and awe is oversize (to me). Huge prints, either backlit or flat mounted to aluminum (see Jeff Wall). Too bad Cibachrome is defunct - those were the best for reversal prints from trannies, massive saturation...but backlit type R's can be very nice.
Certain subjects may look nice in a 4x5" contact print, but I really think that contact printing is more rewarding with 5x7 and beyond (my experience is limited to 4x5" contacts here).
If you plat put a transparency on a light box - try to figure out how fast the image will fade (depends on several variables I suppose).
6 shots into a format and i'm already hearing to move to a larger camera -- seems counterproductive, roger as i've got the graflex in hand- -
Sorry... The only alternative is an enlarger. An 8x10 enlargement is indistinguishable from a contact print.
But I really don't use 4x5 much any more, and almost never for contact prints.
So just have a nice neg/slide scanned and printed (I would go with at least 16x20"). Tough if you have just 6 shots as of now - you may need to do some more shooting first.
Or just start with contact printing and see how it works for you.
it's certainly different than shooting leicas and rolleis --- wasn't feeling tip top today and went out and did my first few shots- -- we'll see what comes of it
Make 4x5 contact prints then really look at them...there should be enough detail there for them to stand alone at that size...
I have only made contact prints with my B&W negs but have had larger prints made from color negs and slides...
At times I wish I could print the B&W negs a bit bigger but for now the contacts work...
If you have a series of 4x5 images maybe grouping them together in one matt/frame would help in displaying them so they don't appear as small images...
with 4x5 how large can i blow them up and still have them look good?
Depends on your standards.
For me, I think "as big as you like" is reasonable. If you blow them up to billboard size, how close do you expect to stand to it? If you get a scan at 4000dpi, you're looking at 20,000 pixels on the long end.
I had some 24x30 enlargements made from Delta 100(4x5) and it wasn't until I then put a 10x loupe to the enlargement that grain was visible,and that was from about one inch away
So as was stated above,go to almost any size you want.
Regards,Peter
