Quick and dirty film and slide scanning
MiniMoke
2:19 AM
Luxembourg
Need your insights on this:
I'm considering a quick, fast method for 'scanning' negatives and slides without using a scanner. I'm aware that quality will probably be inferior to a dedicated film scanner, but I just want it to be adequate and quick.
I saw these on the big river
Can I use them with the X-E1 and the 35mm f:1.4 or should I get the 60mm?
Thanks a lot for your help!
I thought that those slide copiers attached directly to the camera body?
As noted - color correcting negatives? - I never got that to work (I have copied slides using a Nikkor Micro lens and a light box, and that worked out well).
Got the Polaroïd slide copier with glass macro lens today and did a very quick test on the X -E1 tonight, with the 35mm X lens.
Ok, the focal length is less than ideal for the task, but it was just a first try.
The results are VERY sobering, out of focus (I used manual focus as best as possible) and not looking good!
I don't know how you did it, d b?? Your 'scans' look gorgeous. What copier do you use?? Where do I go wrong??
Thanks for your input
As for color correcting negatives, I would do the following: Shoot the negative with a bit of the space between frames showing and then with the levels adjustment in photoshop just sample the space between frames with the gray dropper. The mask should be removed this way. At least that's the tool I use for correcting white balance sometimes, and it works great.
You should be able to color correct for the mask by shooting raw. When I use Vuescan it's in raw mode, and I have a photoshop action that converts into a positive.
