naos
23 Skidoo
I know it's TTL, but what kind of system does it use? Spot, Center-weighted, Average, Partial or other?
Exposure metering through the lens (TTL), selectively with working aperture. Metering principle The light reflected
by a metering spot in the center of the first shutter curtain. The metering spot has a diameter of 12 mm and thus
corresponds to approx. 13% of the full film format or approx. 2/3 of the short side of the applicable bright line frame
in the viewfinder. Metering range (for ISO 100/21°) From 0.03 to 125000 cd/m2 at room temperature, normal humidity
and f/1.0. For ISO 100/21° this corresponds to EV-2 to 20 or f/1 and 4s (B setting) to f/32 and 1/1000s.
Flashing of the left-hand triangular LED in the viewfinder indicates that the brightness reflected is below the metering
range. Metering cell Silicon photodiode with focusing lens to the top left behind the bayonet.
abenner said:#1 - All metered Leica M's are TTL in that the meter is inside the camera, but don't confuse the MP metering with the M6TTL, because they're not the same, in that the MP only flash sync's at 1/50.
Mackinaw said:I remember seeing a picture of the M6 metering pattern, years back, in the the late-lamented American camera magazine, Modern Photo. It's probably best describd as a "big, fuzzy, round spot." Thinking this way seems to give me good results with my MP.
Jim Bielecki
JNewell said:I'm looking at a copy of that test report (published in June 1985) as I type this.
Mackinaw said:Not that I'm in the habit of saving old camera magazines, but I may have this issue. If so, I'll scan the picture and will attach in another post.
Jim Bielecki
