R2M Question/Help
ray*j*gun
2:15 AM
Philadelphia area
I recently bought a like new R2M from a member and finally shot a few rolls. I noticed that the little rewind crank arm is not snug enough to stay put when I turn the camera on its side or upside down. Am I missing something about the way the little crank arm works? Or is there a remedy to this that someone can recommend. I don't want to loose the little crank arm which would render the rewind like a Barnack.
Thanks
They often seem to 'wobble' away from the closed position - sometimes stopping you winding on if you're sensitive enough not to force it! I've never had one that I though would fall off though. Usually just a bit of an irritant. If it seems loose and likely to fall off the rewind knob you may want to get it looked at.
my experience FWIW
my experience FWIW
Thanks
Ray - Had a similar problem while overseas (Prague/Berlin) and I managed to snap the crank arm off while hurrying to change film. Stupid me not paying attention. Found a camera mechanic in Berlin who "built" a temp rewind arm for me (from Leica parts) and when I returned to Australia my usual mech replaced the arm with "real" Voiglander spare. From my personal experience I would recommend you having this replacement done sooner than later as you may find that that your once in a lifetime shot ruined by lack of frame advance plus blisters on your knuckles trying to rewind the film!!!
cheers and best of luck!
Sam
Thanks guys....I thought perhaps I was missing some trick but I guess its just poor build quality. Shame I have had other Bessas and they were built better than this R2M by a mile.
