Frankie
Speaking Frankly
......I might have fallen off the X100 bandwagon but I'm afraid even if this camera is not everything its touted to be, still a lot of people will buy it just for the way it looks, not that there is anything wrong with that.
There are two German products that defy logic: Porsche 911 and Leica M.
The rear engine Porsche 911 design was contrary to laws of physics [as was the VW Beetle by the spiritual founding professor], but 4+ decades of dogged development efforts created a cult following. However, you will still read [disguised] negative remarks from journalists and critics.
The Leica M VF [M3] was originally conceived for use with a 50mm lens. 90 and 135mm framelines was easy to add, so put it on. Wide-angles was a whole different matter; macro...forget it. Decades of weird lenses Monty Python style, goggles, dual-range... later, a cult following was also established.
There was nothing classic or retro about the M body, compound curves and non-boxy designs were beyond machining operations of the day...CNC was invented much later. The M body design was just "old".
The X100 was never touted to be anything but itself...RFF opinions notwithstanding.
A common and simplistic description about the X100 design was "retro". I would rather call it "true" Japanese style. You will understand what I mean if you had spend time in Japan. I am glad the Japanese people are no longer shy in expressing themselves...instead of hiding behind the "establishment" facade.
I had spent more time than many on the X100 because of a lust for information. I immediately wanted one at first sight because it was "my idea"...a perfect walk-about camera that will not need film/processing support.
I had long believed that it will have modern firmware, but also manual control where matters.
Have SD/XC, will travel.
