RIP Plus-X
Any opinions/suggestions for the current 35mm film of similar speed closest to Plus-X in appearance, without resorting to exotic developers?
Chris
ORWO UN-54 in Perceptol 1:1 will cure your woe.
Or is Perceptol exotic? I've not tried ORWO in ID-11/D-76, but would expect a Plus-X-ian rendition there as well.
Some say fp4+ but I haven't shot enough of either to say for sure.
Discussions and consensus vary.
I like Acros at 100 in rodinal 1:50, but it may look a bit different.
Yeah u can get plus-X bulk on eBay from the last cine rolls, I recently secured 24 feet and yet another 100ft bulk from there.
As long as it has been stored cool, it will keep for a very long time, I add them to the 15 rolls I managed to get hold of in 2011 from various stores.
See this is the challenge: Plus-X looked a certain way yet like all films was flexible in how that look came about with different developers and dilutions.
The films today have their own Look and of course the same applies to developer types and dilutions.
Acros in HC-110 will look like Acros in HC-110. Not like Plus-X in Microdol-X 1:0.
Like I said; TMax100 in Perceptol 1:0 is close.
Okay, let me rephrase.
Which widely available 35mm BW film currently made gives "Plus-X like" results, preferably in HC-110, my most often used developer?
Chris
Try Delta 100, which has "punchy" tones and high sharpness. I like ID-11 as the dev, but I'm sure it would be fine in HC-110. I have used the Ilford equivalent called LC29. Sample pic from M2/Biogon:
It's very strange... Here in Lima usually nobody was too fan of Plus-X, everybody said that FP4 was a "better" film, and FP4 was all the rage for a medium speed film.
Then Plus-X was discontinued and i was surprised to see in forums that it was so missed.
Personally i think PX was a better film than FP4, but i like Delta 100 and TMX better.
Which widely available 35mm BW film of similar speed currently made gives the most "Plus-X like" results,
preferably developed in HC-110 (my most often used developer), and that both scans and prints well?
Chris
Chris
Sir.
There is no definite answer, that's the answer, I recommend that you check out threads like these, there are many many people who has asked the same question and many have also tried various replacements and share their experiences:
https://www.flickr.com/groups/67377471@N00/discuss/72157627295896876/
http://www.rangefinderforum.com/forums/showthread.php?threadid=155786
http://www.rangefinderforum.com/forums/showthread.php?t=102278
http://photo.net/black-and-white-photo-film-processing-forum/00aSZR
http://www.apug.org/forum/index.php...ame-similar-to-plus-x-and-pan-x-kodak.131196/
http://silverbased.org/plus-x-kodak-woes/
Trough google, you will find even more discussions regarding this and it seems that the conclusion differes from person to person, but I can see that FP4 is mentioned a lot.
Yes we understand the question!!!
You don't seem to understand the answer.
Like I said! TMax100 (a commonly found film) and Perceptol 1:0 (an Ilford version of Micrdol-X again very commonly found) try this combination since to me it looks and feels close to Plus-X. Try rating the TMax100 at 64 or 80 for more shadow detail and it helps give a Plus-X look to the highlights.
Indeed, I'm sure there have been similar threads here and at APUG and p.net etc.
But I thought folks at RFF might like to discuss "what's most like Plus-X" here in this Plus-X thread.
I added a bit to make my query more specific to my own preferences. Is that okay?
Also I thought there might be more than one "answer" er, opinion.
Man, this is one tough audience...
Chris
Again; here's the deal; When you use X film in Y developer; it will look like X film in Y developer. Trying to make X film look like K film when using Y developer just means it now looks like
If you want X film to look like the old and gone K film you have to tinker with using Z developer instead of Y developer.
Thats the no B.S. version; a shortcut if you're sharp.
The Kodak Medium speed film widely found processed in Perceptol 1:0 looks close to what a common Plus-X look would be. The spectral sensitivity is slightly different which adds to the difficulty in trying to match. The Perceptol suggestion is not in deference to your commonly used HC-110, its just you'll probably get closer to a "Plus-X Look" with something other than the commonly used HC-110. HC-110 and Plus-X was often used and I used some for some very expired 120 Plus-X Pro but ultimately found DK-50 1:1 suited my ideas for that batch of film. Perceptol is a version of Microdol-X which was often used with Plus-X particularly at 1:3 which would also be a good idea to test to see if TMax100 can look like Plus-X. You might want to try a light green filter for this as well.
Do be a good chap and show us some sample to see how it works. I still have one or two rolls of Plus-X I might shoot as a test against Tmax100.
Plus was the most beautiful film created. Problem is not enough people thought so.
A home darkroom is needed to show off the best properties.
People go for tri x which is a dismal film in my opinion.
Agree with all this. Plus-X had the most beautiful tones, excellent sharpness and not enough grain to worry about. To my eye Tri-X does not look as sharp and does not have the same kind of gradation while TMX is completely different to both of them.
Well, simply responding to the original post, I really miss Plus-X. I have a few rolls left in the freezer, and probably should stp hanging onto them and just shoot!
I also never really got on with HP4. Don't know why - it could be just me, but I find Plus-X a much easier film to shoot and develop.
Plus-X was beautiful.
The closest film in terms of tonality and spectral response is TMY-II. You can shoot it at 200 if you develop in Perceptol, D23, or other speed-reducing developers.
Marty
Thanks for the link.
I won't buy 100 feet of a film I've never tried based on a single recommendation.
Too bad it's so expensive by the individual roll.
Chris
