I stumbled onto Rodinal 1:100 stand development about a month ago, and after 40? rolls of film I have had only one film that was less then optimal.
The list of films I have developed -
Plus-X
Tri-X
Tri-X EI 6400
Rollei Retro 100
Rollei Retro 400
Pan F
Efke KB25
Efke R25
Efke KB100
Efke KB100 EI 200
Efke KB400
Efke KB 400 EI 3200
Ektapress 1600
Kodak Gold 100
Konica Centuria 100
Agfapan 25
The best emulsions for Rodinal 1:100 stand development are the Efke film with the Efke 25 simply mind-blowing...
Welder | Lakes Entrance | Victoria, Austrlia 2008
Bessa R2 | Voigtländer APO-Lanthar 90mm f3.5 | Efke KB25 | Rodinal 1:100 Stand |
View Larger
Plus-X and Tri-X work very well and Tri-X in Rodinal 1:100 produces the finest grained high-speed film I have ever seen, far better than Delta 3200 or TMax 3200...
Snug | Sydney, Australia 2008
Bessa R2 | Voigtländer Nokton 50mm f1.5 | Tri-X EI 6400 | Rodinal 1:100 Stand
Plus-X is no slouch... albeit a with bit more grain.
Broken | Sydney, Australia 2008
Bessa R2 | Voigtländer Nokton 50mm f1.5 | Plus-X | Rodinal 1:100 Stand
Even 20 year-old Ektapress 1600 can come out to play...
Hoodie | Sydney, Australia
Bessa R2 | Voigtländer Nokton 50mm f1.5 | Kodak Ektapress 1600 | Rodinal 1:100 Stand
Check my
Flickr Photostream or
Photo Gallery, for more examples. Check 'tags' or 'Technical Details' for development info.
Here is what you want to know, how I do it...
Films that are shot at speed - 35mm -
Several minute water bath
Rodinal 1:100 - disregard temperature unless extreme heat or cold
1 minute of slow inversions, maybe 20 in 60 secs
3 really hard thumps to dislodge air bubbles, very important
DO NOT TOUCH for 59 minutes, a couple minutes extra will not harm anything(the
DO NOT TOUCH is very, very important)
3 water baths then fix and rinse
For medium format, I change the dilution to 1:125 and be sure to use 500mm of solution per roll. Everything else the same.
Pushed film, such Tri-X EI 6400 or Efke KB400 EI 3200...
Every 30 minutes swirl the tank, like you would a glass of wine, for 15 seconds. Do not invert!
Total time - 120 minutes
That is it.
Some notes...
Expose for the highlights, you will have no trouble with shadow details. Very important to not over-expose as you can quickly lose highlights, if in doubt under-expose a bit.
Negatives will come out of the tank quite 'flat', even when shooting a very high contrast scene. Add contrast when printing or scanning.
I will often put 5 rolls of different brands and speeds into a Jobo 3500 tank and all come out fine. I normally use the 2 roll Jobo 1500 tank with 2 reels.
How easy is that...
