venchka
Thank you!
Thanks Wayne.
Did another roll, ERA 100. 1+100. One hour exactly, inversions for the first minute then didn't touch the tank for the hour. Very contrasty result, but even development this time. I'd like to get low contrast in the negs - should I dilute the developer further or cut the time?
When you say, "expose for the highlights" (which I fully appreciate based on my results so far), tell us how you do that. I can think of a couple different ways to do that. What method do you use?
I've never tried it but I believe HC110 can be used for stand development as well. It should work on the same principle: 6ml minimum developer to develop one 35mm roll, if you should be able to leave it for an hour with no agitation for good shadows, and it shouldn't over develop as all the active developer will exhaust.
Chris,
The other common developer that is used for stand development is Kodak HC-110. The was a big discussion on Nikon Café about 18 months ago that discussed using HC-110 as a stand developer quite at length. The infamous Noctilux master and banned RFF member, Ned aka NB23, used HC-110 as a stand developer almost exclusively. He would be happy to fill you on the details, I know RFF member Chris101 still is in regular contact with Ned.
I am not a fan of HC-110 since it seems to 'smudge' the grain losing quite of bit of detail. Just my opinion...
I am sure there are other developers to use as stand developers, a search over at APUG should reveal a treasure trove of information.
As for finding Rodinal, contact VanBar - <vanbar.com.au> - they usually have plenty in stock at about $20 for a 500ml bottle. If not, I know of several local shops with Rodinal on the shelf, I can pick a few spare bottles for you.
Chris,
