The fun with Rodinal stand development never ends...
So I am trying find the absolute limit of Tri-X when stand developing with Rodinal 1:100. So I loaded a roll of Tri-X 120 in the Norita 66 the other day, set my light meter to ASA 6400 and under-exposed another 2 stops, so I effectively rated this roll of Tri-X at 25,600. I had just bought this 3kg hunk of glass and brass called a
Meyer Optik Orestegor 300mm f4.0 for the Norita 66 and figured some low-light, wide-open, hand-held shooting would be a bit of fun. Well, at least I got a sore arm!
Well the results are in...
Reading | Sydney, Australia 2008
Norita 66 |
Meyer Optik Orestegor 300mm f4.0 | Tri-X EI 25,600 | Rodinal 1:100 Stand
The Daily Telegraph | Sydney, Australia 2008
Norita 66 |
Exposure would have been around 1/250 at f4.0.
I used 500ml of Rodinal 1:100 for 150 minutes. Started with one minute of slow inversions and then a 15 second swirl at 45 minutes, 90 minutes and 120 minutes. As you can see I ended up with uneven vertical development and the negatives were under-developed. I reckon that I could have given the film another 30 minutes in the tank.This is the first time I have had uneven development when using stand developing. Also the negatives were under-developed, so I need more time and touch more agitation next time.
This combination has potential and I think the negatives would have printed better than they scanned. I am already formulating a new and improved method to get Tri-X to 25,600 with a decent result.
Wonder how far I can push this...
