pvdhaar
Peter
If you look at this from a slightlty different perspective.. replacable sensors already exist for a long time, and are offered by Pentax, Nikon, Canon, Sony and a couple of others. They're called DSLRs.
You get to keep your lenses and every couple of years you can upgrade the body. As the sensor and accompanying electronics constitute the major cost component of the body (and as Varjag explained are very much are tied into each other to form a complete system), it makes perfect sense to produce and sell them as a single item.
It's not only cost effective, it's robust as well; if you've ever had a modular medium format system like Hasselblad/Bronica/Rollei e.a. you'll recognise that the modular approach is nice if you're going to swap between finders, film backs and pola backs every couple of minutes, but that it's also prone to jamming, bent darkslides, interlocks, wrong settings and what not. They are compromise systems, trading dependability for versatility. A DSLR is a lot more reliable.
So, you've already got what you asked for.. just in a different form. Not only do you get the sensor, but a couple of buttons to press, and a means to see what the sensor will capture as well.
