RFFan
A while ago I came across a warning on the ‘net that old manual rangefinders should NEVER be left with the shutter cocked for any length of time as this will cause the spring to lose tension and hence shutter speeds to become unreliable.
Since reading this I always make sure that I only use the film wind-on immediately before taking a photo hence ensuring that the spring is only under tension for a minimal period of time.
My question is: is this advice correct or just a popular myth? Also, does this ‘warning’ also apply to high-end equipment (e.g. Leica) or only to ‘lower-cost’ mechanical RFs (e.g. Canonets, Hi-matics etc? Finally, is there a 'safe' period of time for which the shutter can be left cocked e.g. between shots within a day but, say, NOT overnight?
