Get an enlarging lens..something that is actually made to be flat field.but should it be this bad with a dedicated macro lens?
Setup: GFX100/ Nikon Printing-Nikkor 105mm f/2.8 A
Sorry if this has been discussed before. I didn't feel like checking back all 17 pages.
Has anybody used this widget?
https://www.negative.supply/35mm
Regular macro lenses may be better..or most likely worse..in this scenario..
Make sure your sharpening settings are turned off. When I import RAW into LR, I notice that it Automatically applies sharpening.
To get rid of the corner lightening, experiment with different distances from your light source and try to make sure that you are parallel to the light source (does not have to be perfect just eyeball it as angling it can influence light intensity).
Also point it at the sky (daytime obviously) to see if there is a difference.
I scan with the emulsion side (matte) to the lens, as that supposedly is meant to be the way, but have not noticed much if any difference.
Another attempt - this is Delta 400.
Jeff From Jacksonville by Vince Lupo, on Flickr
I like the tones I'm getting from the scans, just not sure about the whole graininess thing. Mind you, I never liked how Delta 400 looked.
