FrankS
Registered User
How's the rangefinder alignment?
back alley said:the r4m is here!
just arrived!
i didn't think they delivered after 4.
joe
i just ordered...
4 lenses, all black...
15/4.5
21/4 (old style with finder)
28/3.5
35/2.5 (classic)
4 ltm adapters
this should do it.
joe
sockeyed said:There goes our national trade surplus.
John, I think the 21mm G lens is a good solution, as you get a fast and truly great 21 for a bargain price... Indeed this is what I did too! In addition to the benefits just mentioned, this combination, I figured, partly/mostly avoids the same two-viewfinder problem the Bessa R4 addresses, in that the Zeiss accessory viewfinder has centered crosshairs to pinpoint the AF spot so you rarely need to use the body VF at all.foto_fool said:But then I could not muster the gumption to lay out for a ZM Biogn, much less an Elmarit. So I split the difference - KEH is sending me a 21/2.8 Biogon for my Contax G.
I'm wondering if I'm going to end up wanting to chew my arm off to get away in the morning. - John
back alley said:i just ordered...
15/4.5
28/3.5
35/2.5 (classic)
4 ltm adapters
this should do it.
joe
i just ordered...
15/4.5
28/3.5
35/2.5 (classic)
4 ltm adapters
this should do it
Joeback alley said:noel, i never had a 12.
VinceC said:>>My lecturer at Leica School many years ago said that "he could teach us to use the equipment, to develop and print the pictures, but could not teach us to "see" a picture," you either could or you could not.<<
That's not good advice. The classic rules of composition are straightforward and easily taught, as are the concepts of peak action and decisive moments. I once taught a class of 5th and 6th graders photography, and they were surprisingly good at the end of the year. Learning photography is mainly about learning a visual language instead of an accoustic or written language. And all language is teachable.
I disagree - I think it's a circular thing, and seeing and composition complement and reinforce each other. Learning about composition certainly helped me to see picture possibilities better, so that seeing and composing are now two aspects of the same event for me and it's impossible to separate them.He used the word "see" not compose, you can most certainly teach composition. you have to "see" the posibility of a picture first before you can compose it!
oscroft said:I think it's a circular thing, and seeing and composition complement and reinforce each other.
Yes, that's very true.Maybe. If there IS the ability to "see" at all. If not, it can't get reinforced by learning composition rules
