Show me your Canon RF camera
Picked up a pretty nice copy of the Canon LTM 50/1.4 to use with my Canon 7 and Leica M2.
xwRWLnCifcSv1kcJ1mfjQlRaS_Ckk-RGsJGiCoL3tkirAvFV4ftnSa06LS44ffa1ydQ3gpGlQbOjCsblX-dyqa_QWwjMWD8cPAB4ptUBoCVM7bFwGh4_cDdkDgzj2Ps2L5mlL8vdV3A=w1000-h750-no
Looks great! I also think you'll like this lens, Colton. Incredibly versatile, with great performance for the price. Also balances well on larger cameras like the Canon 7. I use mine on the (portly) Leica M5.
I'm sure you've seen this thread for the lens. Look forward to seeing your results! 😀
You are going to like that lens Colton.
I recently picked up a nearly mint 7 with a Japanese Summilux. The lens is beautiful. Took the place (for right now at least) of the Pentax 50 1.4 I converted.
I'm looking forward to seeing what this lens can do. I don't usually shoot much faster than f/2.8, but it will be fun to play around with the 1.4 🙂
It is a big lens, but does fit the Canon 7 perfectly. I think if you were to remove the glass from the 50/1.4, the Canon 50/2.2 would fit inside it 😀
My QL17 GIII. I also have a Canonet 28 which I bought for $1 at a camera show and works perfectly.
The missing JCII sticker spot looks horrible in this photo, made soon after buying the camera, but looks OK now that I've cleaned it.
Here's my "E-P" II-F, from 1953.
attachment.php
The lens mounted to it is a W-Nikkor-C 3.5cm/f3.5. The lens to the right is a Canon 50mm/f1.8, which I believe came with the body originally. I also have the leather neveready case.
It came to me dirty, and with an aged and ripped 1st shutter curtain, but apparently hardly used. I replaced the 1st curtain, lubed the the shutter and advance gearing, and now it's a fun shooter. The Canon 50mm/f1.8 lens is great. I shot the first roll of film using it and was impressed. I just got the Nikkor 35mm lens from a friend, and have another roll of film in the camera now.
VTDM just arrived. Looks like it is in very good shape, viewfinder is clear and aligned properly and the metal shutter curtains are in great shape. The trigger winder might need a little bit of cleaning as it doesn't quite return to its original position without a little help.
Shawn
