snaefell
You may be thinking about the Mamiya 7. When fitted with the 135 kit, that camera produces exactly the same size negatives as the Xpan.
That's right. Sorry for the confusion.
The vertical dimension has nothing to do with the width of the frame on a Mamiya 6 (or 7), since the film is loaded left-to-right. On a Rolleicord or Hassie the film is loaded bottom-to-top, which then limits the frame width as you say.
No, the Mamiya 6 MF (the original M6 doesn't support the adapter) would produce a 24 x 56mm negative (1:2.33 ratio)
The Xpan negative is roughly 24 x 65mm (1:2.71 ratio)
But the M6 is a square format camera, hence the negative width is limited by the 56mm vertical.
Catching up on a backlog of 6x17 and 6x15 images.
Wow, nice collection. Keep on catching up 🙂
Untitled by Hogarth Ferguson, on Flickr
