Show your photos from a vintage folder
I experience the same problems with my Super Ikonas and Moskwa 5 when using them vertically. My strongest concern is how to hold the camera steady at long shutter speeds like 1/50 or even 1/25 s.
What is your technique?
I don't think I've standardized a technique yet. One thing I do consistently is focus with the camera in landscape orientation, then turn it. (This of course precludes photographing any fast action, but I am never using the Ikonta for that anyway.) I then proceed to fumble around with different ways to try to get a grip on the camera, since the usual "eating a sandwich" grip with the left hand does not work well in portrait orientation. I find that I often come close to gripping it in some way that accidentally trips the shutter release! So I'm still trying to find a good, repeatable way to hold it. The obvious answer is, put it on a tripod and turn the tripod head, and use a cable release. But that does not always work of course, if you didn't bring a tripod or, as in the case of this picture, cannot use it. (There was a low fence in the way exactly at the distance where I needed to set the tripod. So instead I leaned on it.)
--Dave
I agree that there is a real challenge to holding a 6x9 folder steady for a vertical shot.
I shot this at 1/5, and if you look closely, you can see that I was unsteay. Oh well, no second chances for reshooting this.
Super Ikonta with Tessar:
This is my first foray into medium format. These were taken with a No 1 Autographic Kodak Jr circa 1920. I think it belonged to my parents although I never saw them use it. It has been lying in a box of bits and pieces I took with me when I left home over 40 years ago. I recently had it CLA'd including re-gluing some of the cover and polishing it up. I'm very pleased with the results from such an old camera although there is a light leak I will have to track down. Any suggestions as to where to start looking?
cheers,
clay
For the light leak, use one of those new super small light weight led flash lights. Put it inside the camera w/ the bellows unfolded and the rear film swing door close... Find a dark room any light leak should show up.
Gary
Chiesetta con nebbia in Perchia, Umbria Italia
Zeiss Super Ikonta 533/16 Kodak 160
Zeiss Ikon Ikonta 523/16 with Opton Tessar, Arista Edu 100, Caffenol CM
I shot most of these around f4-5.6
I was pretty happy about the tones coming off the foliage
Thread viewers
