kermaier
Has anyone here ever seen a Leitz Summaron 35/2.8 in LTM that focuses down to .7m?
::Ari
::Ari
There are 3 versions of this lens.
Screw mount version (SIMOO later code 11006) focusses to 1 metre.
M-mount -M3 version(SIMWO later code 11106) with rangefinder attachment focusses to 0.65 metres.
M-mount -M2 version(SIMOM later code 11306) focusses to 0.7 metres.
AFAIK, early .7m M mount lenses were made with an LTM mount and an adapter. So maybe what you saw was originally an M2 / 0.7m lens with adapter removed. Not sure if the lens will be collimated correctly on an LTM body if used as is.
The other option is that somebody put a Summaron head in a late screw-mount Summicron barrel. Should be visible though via the DOF scale.
Roland.
Can you show a photo of the mount, Ari ? If it stems from a goggled version and focuses fine, the RF cam must have been ground as well (for correct focusing, similar, say, to the cam of a Summicron 40/2). Would be interested how that was done.
Thanks !
Roland.
Sorry, I don't have the lens. I was looking at it in a camera shop yesterday. What's a Summicron 40/2 RF cam look like?
::Ari
It's slanted, Ari. To make a googled Summaron work without googles, one has to correct the focus distance by factor 1.4. This can be done by grinding the cam, in a diagonal (no change at infinity, a couple of millimeters at close focus, linear in between). Hope I explained that right.
Best,
Roland.
Best,
Roland.
i spoke to Focal Point last week about removing the goggles from a V1 summilux. he said there is no way to adjust or collimate the removed lens to work without the goggles. he's received dozens of them over the years that had the goggles removed by camera store repairmen and there is no way to make it work.
there is a different focusing helical in these lenses and they cannot be altered to work without the eyes.
bob
The Summaron cam rotates and therefore it can be done. Look at the back of your Summilux. If the RF cam rotates, in theory it's possible. I'm sure John could do it. He might not want to file the cam of a 1000$ lens though ...
Roland.
