Summicron IV Aperture blades; Is this normal?
everyXnewXday
8:37 AM
Hi, new owner of a 35mm Summicron iv. Is it normal for the aperture blades to show this much when wide open? Bokeh highlights aren't round.
Thanks!
Its actually an f1.85 lens but Leica has crippled it by installing a measly maximum aperture opening of f2! Sheesh! 😱
Seriously though, I suspect its a deliberate design policy by Leica to reduce vignetting at maximum aperture.
I've owned two 35mm f2 version IV Summicrons.
One from 1984 and the other a late chrome German one.
The 1984 did not show aperture blades wide open, but the later German one did.
Now I know why they released a Summarit 35/2.4
Kidding aside, Had a v4 and at f/2 i can also see the aperture blades
Same here. Looking at my 35 Summicron V4 from the rear, no blades are visible - but they are just about, seen from the front.
No aperture blades visible in mine at any angle at f2. Just kidding. Mine is German, a chrome one, and I can see this much aperture blade at a slight angle. This photo is a close up wide angle shot. If I hold mine at arm's length and look at the front you can barely see these aperture blades.
Thanks everyone! While I'm at it, is it also normal for there to be an extra 1/3 stop or so after f/16? I.e., after f/16 the aperture ring turns a bit more (but less than 1/2 stop) and the aperture opening then becomes perfectly round. It is not quite round at f16.
Thanks again!
