RF-Addict said:
Anything else?
Do you use DX coded cartridges? How big is the risk that the film will be scratched during loading?
Is there color bulk film as well?
Labels. If you are in the US or Canada, you can get inexpensive labels at Staples made for inkjet or laser printing. I found the best sizing and value for me is Item # 13939, Staples brand. The labels are 3/4" x 1-1/2", 14 labels per sheet. Yes, the sheets are small. I load them in the manual feeder of my laser printer (Brother HL-2070N). The word-processing template is downloadable from the Staples site, and it works perfectly in Open Office Writer, so I assume it will work as well in Microsloth Word.
Just beause I bulk load doesn't mean I like sloppy handwritten labelling on masking tape (ugly) ... printing out neat labels makes me feel better. So sue me!
I have virtually no problem with scratching. Years ago when I started I had more problems. Then I figured out I should keep all the empty cartridges in a sealed container until use. I use Lock-n-Lock containers for that; they're air and water tight, a joy to use. The size I use holds > 25 empty carts, a pack of labels, a can of 100' of film, and room to spare. I keep my bulk loader and the Lock-n-Lock next to each other.
I don't use cellophane tape as I don't like the residue. Right now I'm using masking tape, but I think I'm going to change to a plastic tape, like the stuff Kodak uses to secure the film to the spindle.
Before reusing a cassette I run the adhesive side of a piece of masking tape over the felt strips. That picks up any stray grit that may have become embedded. This is one of the secrets to avoiding scratches.
The Watson and Alden bulk loaders don't have felt in them, at least the ones I've had; they have a gate that you open when the lid is closed and you are ready to roll. I would avoid loaders with felt, but if I were to use one, I would use the method above to keep the felt clean.
I don't use DX cassettes. I would often override the ISO setting on my camera anyway, so DX would be a hassle.
I don't bulk load colour film simply because I don't shoot a lot of colour. But if I did, I would. For C41, at least.
