Tales from the Greasy Side, Wartime 5cm f1.5 Sonnar "T" and Lens Horror Stories!
Wartime 2726xxx CZJ 5cm F1.5 Sonnar "T", Basket Case, $75.
As received. Front element coating damage, fungus marks. Rear group- fogged. Metal corrosion.
Replaced front element with a 1939 element from an incomplete lens.
Replaced rear triplet with a KMZ.
Replaced the focus mount.
When shimmed for proper focus, the F-Stop markings aligned perfectly with the Index Dot on the pre-war mount.
The Middle Triplet is in good condition, coating survived.
A good thing: It had Canadian Balsam holding it in place. I've seen this once before- the triplet was "hot mounted", the barrel used to help center the triplet. I did not try to force it out, I've learned the hard way to quit while ahead and go for a 95% solution.
The knurling of the Wartime Sonnar is about 1mm wider than the pre-war.
The KMZ rear triplet is a drop-in replacement for the Zeiss. Fits perfectly into the Zeiss fixture. The ZOMZ and Valdai are different shapes and not Schott glass.
Lens looks and works much better now.
I ended up converting this one to Leica mount using a 1951 KMZ focus mount. The KMZ is going into Contax mount.
