S
Sean Reid
Guest
Two comments:
1) I think it's worthwhile to separate one's feelings about the medium from one's feelings about camera designs and systems. I very much like digital (as a capture medium) but I'm not crazy about the modern AF SLR (film or digital). The R-D1 is the best example, that I can think of, of a camera that combines traditional design and controls with digital capture. It would be good to see more. The pros and cons of AF and other various modern camera systems should be independent of the pros and cons of capture medium.
2) As a poster mentioned above, the deep (perceived) DOF in small-sensor cameras comes from the very short focal-length lenses they're paired with. Of course, if subject distance and size remains the same, the shorter the lens the greater the apparent DOF. The Leica Digilux 2 gets it's (approximately) 28mm-on-a-35mm-camera FOV from an actual focal length of about 7mm.
Sean
Sean
