Sonnar Brian
My best performing 1950 Jupiter-3 was out of spec: the Focal Length was too short to focus across range when I converted it to Leica mount. It was originally in Contax mount, and could not go deep enough into the mount to focus at all. One of the few J-3's that I increased the distance between front/rear groups. The plus side: the glass is perfect as the lens could never be used. Zeiss serial numbers, 1945 production.
I've seen many transition lenses, ones that others call "fake". They are not. I have 5cm F1.5 in Leica mount that had an unfinished middle triplet- as in not properly polished. I replaced it with the middle triplet from a KMZ J-3, is a fine performer optically. The mount itself- lots of slop in the barrel, required heavy grease. I have one proper 285xxxx 5cm F1.5 that was full of sand and grit, the helical so worn down that I made a Sleeve for the mount to keep the lens centered as it was used. Worn front coating, but great images.
The Zeiss factory was in shambles after the War. What some call "fakes" are just the Zeiss workers Surviving.
Side-Note: 1956 marks the change-over in the J-3 from KMZ to ZOMZ. The design changes. I suspect that KMZ stopped manufacturing the J-3 when the supply of Schott glass was used up. The shape of the rear triplet changed, the fixture also changed. I'm been watching KMZ SN's go just past 5604xxx, have one on the way now.
Do you know how high KMZ Jupiter-3 Serial Numbers go up to?
