f16sunshine
Moderator
What do you use ?
What else have you tried and how did it go?
Thanks
Thanks
Dogman
I don't have an X-T1 but I have several other Fuji models. I've always used Sandisk Extreme Pro 32GB cards in the the Fuji cameras from the beginning. At the time I bought my first Fuji, the Extreme Pro had been recommended in reviews so that's what I went with.
I've always been partial to Sandisk and Lexar cards with other cameras although Transcend and Kingston cards worked fine in them as well.
majid
Fazal Majid
Sandisk Extreme Pro UHS-II 16GB 280MB/s, B&H part SAEPSDU16GBQ.
The 280MB/s figure is pure fantasy, but it's a fast enough card.
Keep in mind Sandisk regularly updates it's "Extreme" and "Extreme Pro" lines, so make sure you do not get old stock of previous-generation cards (or at least pay a discount).
Make sure you get a UHS-II card and that you get it from a reputable vendor, as a huge number of "Sandisk" cards out there are counterfeit.
Beware of Amazon—many third-party vendors sell counterfeit products, and even when you order from Amazon itself, they have something called "commingled inventory" where the card you are buying may be inventory of a third-party merchant. They have apparently started cracking down by requiring sellers of frequently-faked brands to post a bond, but it will take a while to work its way through the system.
narsuitus
At one time, I used bargain quality cards because they stored my images just as well as the more expensive high-quality cards.
However, after I lost a few images due to card failure, I decided to use only high quality cards. I now use SanDisk, Lexar, and Toshiba.
I routinely use cards with average write speed. However, when I am shooting video, I use cards with a faster write speed.
Memory Cards by Narsuitus, on Flickr
Big Ursus
When I asked a local store about that card, they said the expense wasn't necessary unless I shoot video - which I don't.
Can you explain why you chose it? I'm waiting for my pre-ordered X-T2, and I'd appreciate any information you could give me.
f16sunshine
Moderator
I went with the Lexar x2000 uhs-ii as the latest upgrade.
It's dramatically faster. I only shoot single frames and after 45 frames consecutively stopped as I would bever even reach this sort of rate.
The write light stopped flashing 1/2 second after I stop firing..... Very good.
Camera was set to RAW +FINE(Small).
