The bigger the sensor, the smaller the problem
I wouldn't exaggerate the difference between (micro) four thirds and APS-C. Of course the high ISO advantage of APS-C over (m)FT roughly corresponds with the difference in sensor size, but not everyone needs these speeds on a regular basis. Also, while I've yet to see a pancake for APS-C mirrorless cameras faster than f/2, the Panasonic 20mm/1.7 is an excellent lens and when used at full aperture can already compensate for the mFT ISO disadvantage compared to, e.g. the Samsung 30/2 with a similar form factor (and as far as I know there is no such option yet for the NEX).
However, I must admit that if a mirrorless EVF camera were my only one, I would tend to an APS-C model as well. As it stands though, the higher crop factor and larger DOF of mFT make a nice companion for a camera at the other end of the spectrum (full frame/APS-H) and at least to my mind complement such a camera better than an APS-C cam would...
I'd suspect High ISO performance is more important to DSLR users since they generally use slower lenses. It's much more convenient to consumers to have an entry-level DSLR body which has a usable ISO3200+ then fork out $1000+ for a zoom that still only has a maximum aperture of f2.8.
great point.
I've been shooting the NEX-5 for a couple months now with the 16/2.8 and adapted 50/2 and 28/2. I've tested the Ultron focused to infinity at F2 and saw no corner smearing or color shift. If you can live with manual focusing on the screen, the 28/2 makes a great companion to the 16/2.8 for a two-lens kit. As a RF user, I don't use 90% of its features... I shoot aperture priority and change the ISO and exposure comp. That's about it. Ok, being able to do HD videos is handy, too.
Sure, I'd like to see IS and EVF on the 2nd generation NEX, not to mention a more mature E-mount lens lineup. But for it's target market, the NEX-5 hits a home run. I can't live with the 2x crop factor of m4/3 but 1.5x is ok for my adapted lenses. Zeiss is slated to release a wide angle, fast E-mount prime in 2011... some rumors say 35/1.4.
You can score the NEX-5 kit with 16mm for under $600 if you're patient (entry-level DSLR price). How many cameras under $1000 have the same resolution screen? It's a heck of a deal, esp since I don't have to buy more lenses or a big zoom to shoot the FLs that I want.
I haven't tested the NEX5, but being an APS-C DSLR user (D300), I want to comment on high ISO capability:
In the recent weeks, I spent several evenings on the Munich Oktoberfest doing night-time street photography. I set my camera to Auto-ISO with a min. shutter speed to easily allow hand-held photography (1/160s for EFOV of 28mm and 35mm). And I selected a rather large aperture (f4) because I wanted to see what kind of a performance I could get out of my camera's AF system (more about that later).
I had intended to shoot for BW conversion - so I set the camera'a auto ISO mode in such a way that it would use its capabilities right to its design limits. It turned out that my camera worked fairly conservatively: It would only increase ISO if it had reached the specified min. shutter speed. Nevertheless, the camera had to go up to 3200 and 6400 ISO in about 30% of cases (it was really dark at times).
I routinely converted my results into BW, and in BW, I think the pictures were perfect even at ISO 6400 (see examples in my gallery)! Mind you, DR will decrease, so exposure accuracy becomes more important, and decreases in resolution actually become visible starting at 1600 ISO (film is no better), but noise never became a problem in BW.
For curiosity, I looked into the color versions, and after having learnt more about film and its capabilities, I must say that even the IS0 3200 image files compare favorably to what I would expect from pushed color negative film!
But there's another benefit of modern digital technology, and that's autofocus (phase AF in my case). The trick is the capability to focus on the nearest object, and to use face recognition - plus dynamically following moving objects. It actually works. I got amazing results - I had an AF a hit rate that was better than guesstimating manual focus, with interesting OOF rendering because I could effectively use much wider apertures (I shot most of my Oktoberfest series at f4.0. IMO, zone focus only makes sense for these focal lengths if you work at f5.6 and above.). Any wider apertures are problematic because low-light AF accuracy still isn't perfect (but it's good enough in most cases).
What does that mean for my assessment of X100 performance: If that camera's auto ISO performance is similar, then it will be a very useable street camera.
As to AF under low-light conditions, I'm not so sure because contrast-detection AF inherently will be slower and has more tendency to hunt. Thus, I guess this will mean a more intense use of zone focussing. That won't be too much of a limiting factor because if auto ISO mode reaches a similar IQ as I get with my D300, we are indeed looking into a bright future with the X100.
Arjay
I just had a look at your gallery and it seems to confirm the points you were making, nice job.
Bob
