OlliL
Focus peaking?
M-Mount adapter?
M-Mount adapter?
i don't think it's bad looking at all. the proprietary strap lugs, though: why make it difficult to use one's own favorite strap? so the owner has to use one with canon printed on it, i suppose.
Your 5 year old niece has a cell phone? 😱 I'm getting old...
I don't see any difference between this and the Olympus OM-D that everyone seems to get wet dreams over. Both are ugly. So what??
I would humbly suggest you try a Nikon 1 series out for a while. I am using the V1 and consider it an extremely capable camera.
Boring specs, boring implementation (no innovation whatsoever), and even worse looks.
Canon EOS M Specifications
18mp APS-C
DIGIC V
ISO 100-12800 (25,600 Expansion)
3″ Touchscreen 1.04million pixels
Phase & Contrast AF
Video Servo AF
1920×1080 Video 30p/25p/24p
1280×720 Video 60p/50p
MPEG-4, AVC/H.264
SD Card
Adaptor at launch for EF lenses
Additional specs
Hand-held Twilight mode, to help with long exposures in low light.
Multi-shot noise reduction function that helps reduce the noise by combining four images.
The usual creative filters
HDR mode to synthesize three different exposures
Camera size: 66.5mm (width) 108.6mm (height) x 32.3mm (depth)
The weight (body only) 262g, (including battery and memory card) 298g
Well, according to dpreview, they've copied at least one aspect from the Fuji. Slow focusing!
well, at least now, a full frame mirrorless is really possible.
"The EF-M mount is 58mm in diameter, with a flange distance of 18mm from the bayonet to the sensor. As the image above clearly shows it's matched specifically to the APS-C sensor size. So don't expect a future full frame EF-M mount camera - it's not going to happen." From DPR
I meant an EF mount since they gave in to the mirrorless trend and have the full frame lenses... something which has been stopping the other mirrorless players.
Sure, but if they go EF mount the camera's not going to be thin due to the large flange-to-sensor distance in the EF standard. So they'll end up with something that might as well have had a mirror box like the Pentax KO-1.
What Canon is saying here by introducing a 1.6 crop mirrorless is unambiguous: Panasonic and Olympus [2.0], Fuji and Samsung [1.5] all have found the optimal balance between sensor, lens, and camera size, and image quality. And for most people, that balance does not favor FF.
