The following is simplified in a number of ways, but that's just not right.
TMAX400 developed in D-76 has an MTF-50 of 80 cycles/mm and its maximum resolution is about twice that [
Kodak technical bulletin].
160 * 24 = 3840 cycles/image height.
The Monochrom sensor is 5212 x 3472 pixels.
The
sampling theorem tells us that we need to take discrete samples at ≥ twice the frequency of the signal to accurately reconstruct the signal.
To match the resolution of TMAX400 we'll need to sample at around 3800 x 2 = ~7500 pixels per image height (~7400 dpi)
That requires a 7500 x 11000 monochrome sensor, and an 80 megapixel image file.
Use Tri-X instead of TMAX400, and the Monochrom gets close. Use TMAX100 or ACROS, though…
